Vault General Discussion
Product Support
r.smith1
Message 21 of 25 (687 Views)
Re: Vault 2012 Copy Design error; Value cannot be null; Parameter name: value
06-14-2011 02:30 PM in reply to: Studioworx
Hi Dan,
Thank you for your reply.  In our tests, you can set the ipj at the working folder root (example: C:\_Work) and then point your workspace to the workspace folder.  In another test, I set the IPJ file in $\ but it was mapped to C:\_Work and workspace folder was set to .\.
I hope this helps.
Ron Smith
Front Line Technical Support Specialist - Data Management
http://help.autodesk.com/view/VAULT/2014/ENU/
http://crackingthevault.typepad.com/
http://underthehood-autodesk.typepad.com/
Active Contributor
Studioworx
Message 22 of 25 (673 Views)
06-15-2011 12:09 PM in reply to: r.smith1
Hi everyone,
The Value cannot be null error has been solved by changing the working folder to C:\Vault\
Not C:\
I then got an XML error, which I had seen on the cracking the vault blog.
http://crackingthevault.typepad.com/crackingthevault/2010/11/there-is-an-error-in-the-xml-document.h...
So I turned off AVG link scanner and all is absolutely fine.
Ron, I noticed the workspace was set to .\ all seems to work ok so I'm not going to change it.
Thanks everyone.
Dan
nijpels
Message 23 of 25 (651 Views)
06-17-2011 04:52 AM in reply to: r.smith1
Hi Ron,
Thanks a lot for helping, the problem is now solved for me.
Only thing I had to change would it work was to set to enforce the working folder. Only after that the error was gone.
But it works for me now, I'm the only user.
Thimo Nijpels
Comus Technology BV
Netherlands
http://www.dry-reeds.com
nijpels
Message 24 of 25 (601 Views)
06-29-2011 11:27 PM in reply to: nijpels
Hi all,
There is a hotfix now availeble for this isue, see message on the other thread http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-Copy-Design-Error-Value-cannot-be-null/td-p/.... by Fay Zhang.
To go to the hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235740&linkID=9261341
Thimo Nijpels
Comus Technology BV
Netherlands
PACDrafting
Message 25 of 25 (410 Views)
03-22-2012 06:17 PM in reply to: nijpels
Is there a copy design fix for 2011 also?
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
