Hi All,
I have just installed inventor 2012 it works great, installed Vault that was ok as well.
now when I started to look at our backup plan, things started to go wrong problem as follows.
I can back up the vault manually to my C: drive but when I try and create a scheduled backup through the vaults new schedule tool, it come back with unable to create full backup task.
The other problem is I can’t even back up manually to the network only the local dir
any help would be great i'm pulling my hair out
Solved by Andy.Spivey. Go to Solution.
The following section of the Advanced Configuration Guide should help regarding the network backup location:
For the issue regarding setting up an automated backup via the Vault Server console, can you provide a screen shot? Another option would be to create a BAT file for your backup, and adding it as a scheduled task (that is essentially what the console automated backup does as well).
Thank you for your quick response,
I am not at work at this moment I will be in tomorrow.
What your saying makes sense editing the SQL and creating bat file.
I will let you know how I do
My pleasure - please let us know how things go.
Is there any error / warning listed in the Event Viewer logs on the machine to indicate what the failure was? (Maybe there is a security policy that prevents a scheduled task to be created by certian users?)
Before I start the version I have installed is Product Design Suit Premium 2012, as this is the standard Vault will the task scheduling work. I have been able backup manually and with a batch file. But the vault scheduling still does not work.
This is most likely caused by a permission issue when creating the scheduled task (it may be UAC related - that would be my guess).
Couple of options - please check to see if your batch file is being created - the default location will be C:\Program Files (x86)\Autodesk\ADMS 2012\ADMS Console
If the batch file is there, you can manually create the scheduled task in windows to run as desired.
if the batch file is not there, you can manually create the batch file - my example bat contained:
"C:\Program Files (x86)\Autodesk\ADMS 2012\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"C:\" -VU"administrator" -VP -DBSC -S -L"C:\log.txt"
You could also check if the following UAC option is enabled (attached image). If so, you can try disabling it and restarting machien and testing again.
Thanks, what I have done created a batch file put it into my task manager. Don't know why but vault schedule want work?
Well one last thing my script is like:
@ECHO OFF
REM DELETE B AND CASCADE A BACKUP SUBDIRECTORIES
RMDIR /Q /S "C:\Backup\Vault\B"
REN "C:\Backup\Vault\A" "B"
REM CREATE A NEW DIRECTORY FOR THE BACKUP
MKDIR "C:\Backup\Vault\A\"
REM START THE BACKUP PROCESS (THIS IS ONE LINE OF TEXT)
"C:\Program Files (x86)\Autodesk\ADMS 2012\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"C:\Backup\Vault\A" -VUtgrimwood -VPassEmble8 -DBSC -S
L"C:\backup\vault\backuplog.txt"
it works except creating a backup log.txt does not any ideas
Be sure to place the -L"C:\backup\vault\backuplog.txt" on the same line as connectivity.admsconsole.exe and the logging should occur.
My thoughts on why the task is not being created automatically throught the console is with the UAC component of the OS.
Thanks that worked fine
just have to get my head round why the schedule want work, but for now I will use windows 7 scheduler
The issue is most likely the UAC, or one of its components, not allowing the ADMS Console to create the scheduled task.
Again, setting the task up through console creates a backup Bat file, and then creates a task inside the Windows task scheduler.
We have the same problem with Windows 2003 Server R2 and I don't have UAC.
How I can fix the problem?
Regards.
Please make sure that the user that is executing the scheduled backup job has correct persmissions to do so.
IE, if you make a new local user named VaultBackup, login to windows as that user and try to run the backup manually through the ADMS console.
Dear Andy,
I have login with domain administrator and this user have all permissions but I cannot login into ADMS 2012 with this user. I have tried "Windows Authentication" and "<domain>\<login-user>" but I cannot open ADMS.
I attached the message errors.
Thanks and regards,
Jose.
Jose,
The base vault product does not support windows authentication. To log into the Vault server console, you will need to login as a vault user. By default, the administrator password's account is blank.
-Andy
Andy,
so far we have never had problems (last version we used, 2010 for example). We have always used the 'administrator' Vault user. We have always run the backup using the command line but now we wanted to use the option "Scheduled Backup" and cannot because it fails to create the task.
Tonight I will test the back-up using the command line.
Jose,
The scheduled backup is essentilaly a BAT file with the command line script under the scheduled Windows task - it can be created manually if there is an issue with the wizard.
Simply take your command-line backup routine and save it as VaultBackup.bat
Next, run the Windows Task Scheduler wizard and list VaultBackup.bat as the program to run.
Next you set the schedule in Windows Task Scheduler and complete and you should be all set.
Andy,
tonight I executed the back-up task with a BAT file and it's works fine but I have an error in the last lines on result log file:
18/01/2012 1:47:25 Validating backup databases ... 15/17
18/01/2012 1:47:28 Validating backup databases ... 16/17
18/01/2012 1:47:31 Validating backup databases ... 17/17
18/01/2012 1:47:31 The backup operation has been successfully finished.
18/01/2012 1:47:31 System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at System.Windows.Forms.Form.ShowDialog()
at Connectivity.Common.CommonMessageBox.a(CommonErrorForm A_0)
at Connectivity.Common.CommonMessageBox.c(CommonErrorForm A_0)
at Connectivity.Common.CommonMessageBox.ShowDialog(String message, String title, ButtonType buttonType)
at Connectivity.Common.CommonMessageBox.Show(String message, String caption, ButtonType buttonType)
at Connectivity.Application.VaultManager.ManagerMessageBox.Show(String message, ButtonType buttonType)
at Connectivity.Application.VaultManager.BackupVaultCommand.OnExecuteCommandLine(String rootBackupPath, Boolean validateBackup, Boolean backupStdContent, Boolean ignoreNonreplicatedFiles, LoginInfo dbLogin, Boolean validateFileStore)
at Connectivity.Application.VaultManager.ApplicationClass.RunCommandLine(String commandLineArgs)
18/01/2012 1:47:32 ***** WARNING: Failed to initialize logging subsystem. Please check your app.config file for valid settings
Jose.
I have not seen that message before.
Can you post your script used to created the backup for review? I would suggest removing the -VP switch that shows the password being used before posting.
