I am getting following error while using "Replicated Folder" on ADMS. (Vault 2011 professional, window server 2008, SQL server 2008).
Solved by varindersra. Go to Solution.
Can you post the ADMS Console log and maybe the Server logs? They are available in the "Management" folder of the ADMS-Console, and they may have more detailed information regarding this error.
-Dave
I am attaching a copy of sever log.
Thanks for reply!
That issue was because I had both Vault client and ADMS console open at the same time. As soon as I close Vault client it doen't give me the error.
Thanks for Help!
For anyone else having this issue, the Flex LM license manager needs to be correctly configured for the "replicated folders" command to work. It appears to consume a Vault license to run this task.
