We are using IV2011 with the basic Vault 2011.
An issue we are having with some users is that when they open a file in Inventor from the Library folder (which is read-only, and used to "store" standard parts), Inventor prompts them to Check Out the file. This happens even though their Vault Status indicates that they have the latest version on their local drive!
This is driving me nuts! Does anyone else have this problem?
Hi "geamike",
Is it possible that these two Blog posts might help?
Thanks for the links, Richard. They were helpful, as I learned a bit more about Vault.....but not in this case!
The files that this user has this happening to are simply .ipt files. Not iParts, just a stand alone .ipt.
Secondly, this only happens to this one user, out of about a dozen of us.
I'm beginning to think he needs a repair or re-install of Vault and/or Inventor.
Again, thank you for the links. I'll be visiting that site more often in the future.
Mike
OK Mike,
You could try the repair\reinstall option. I am not sure it could help though. Here are some other ideas that might help....
If its only happening on 1 machine, you might need to sit down with the user and analyse what is different about that machine from the others. So..
Let us know if any of those helps....
