Hi Frank,
my configuration is:
I have installed Inventor suite 2009, recently I have installed Inventor
Professional Suite 2010.
Even if I start Autocad 2010 and close it (just to register Windows that
should use the new release) if I open the file from the Vault it still open
Autocad 2009.
Even if I open Autocad 2010 and keep it open, if I open a file from Vault
Explorer it opens Autocad 2009.
thanks
A. Maffi
"Frank Ran (Autodesk)" ha scritto nel
messaggio news:6185601@discussion.autodesk.com...
Hi Maffi Pneumax,
If you install ACAD 2009 and ACAD 2010 in the same machine, and then try to
open a *.dwg file, the system will always use the higher ACAD edition to
open the file, no matter the file is in Vault or not.
Meanwhile, I did a few testing based on your discription. and My workflow
are listed below:
1. Install ACAD 2009
2. Install ACAD 2010
3. Install Vault Manufacturing 2010
4. Open ACAD 2009, create a DWG file and then check into Vault.
5. Switch to Vault client, and open the DWG file -->(Result: The file will
be open with ACAD 2010)
6. Double- click the dwg file again in Vault client --> (Result: We will not
open another ACAD application, but just use the ACAD 2010 we launched in
previous step)
So my questions are: Is this the workflow same as yours please? Or did you
make some other configrations please?
Frank
"Maffi Pneumax" wrote in message
news:6185329@discussion.autodesk.com...
Hi Irvin,
this was my first check and I confirm that a double click opens Autocad
2010.
thanks
Alberto
"Irvin Hayes Jr." ha scritto nel messaggio
news:6185195@discussion.autodesk.com...
Does double-clicking on a dwg file in Windows Explorer open AutoCAD 2009
or 2010? It maybe a file extension association in Windows that is
causing this problem.
Irvin
Maffi Pneumax wrote:
> Hi All,
> I have installed on my PC all the new release 2010 (Vault, AutoCAD 2010,
> Inventor 2010).
> I have this tsituation:
> If I open a dwg file from Vault Explorer instead of Autocad 2010 will be
> opened Autocad 2009 (even if I have already AutoCAD 2010 open)
> Is it possible to set which release has to be opened ??
> thanks
> Alberto
