The Vault you have with Civil 3D will have ACL support with 2008/2009, but
the customer with AIS2008 will not be able to leverage ACL's in Vault. There
are better solutions for using Vault than 10 separate Vaults. Since you are
VAR and ATC, consult with your local AE or SE for the best solution for your
customer.
Brian Schanen
Customer Success Engineer, Data Management
Autodesk, Inc.
"Razvan Stancu" wrote in message
news:6073050@discussion.autodesk.com...
> The reason I asked this question is that I see the help of Vault describes
> this function. Also we have a computer with Civil 3D, which theoretical
> hadn't installed the PS 2008 or 2009, but it has Vault 2009 and I see that
> option exists. I will try it on a new installation.
> We are VAR and ATC and he have a customer which has AIS2008 and he wants
> to implement Vault but he needs ACL instead of creating 10 separated
> Vaults for each user or Project.
> Thank you again.
> RS
> "Brian Schanen (Autodesk Inc)" wrote in message
> news:6072930@discussion.autodesk.com...
> Hello,
> This is a feature of Productstream only, either 2008 or 2009. The feature
> is not available for Vault 2009.
> Brian Schanen
> Autodesk, Inc.
> "RStancu" wrote in message news:6072346@discussion.autodesk.com...
> I never needed to use the ACL on Vault folders until now. I see there's a
> Security Tab on Vault 2009, but I didn't saw it on Vault 2008. Is this a
> new feature in Vault 2009? Or it was on Vault 2008 as well? Thanks Razvan
