Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
VAULT 20015 Item Master WITH Inventor tube and pipe
2 REPLIES 2
751 Views, 2 Replies
Why isnt it it possible to assign item to Tube and pipe hoses ? I want to buy the hoses but are not able to assign items to them. I can assign item to the top tune and pipe assy, but not to the sub assemblies wich i need an item for so i can buy it...
2 REPLIES 2
paul.gunn
Vault doesn't support direct item assignment from phantom assemblies (which I believe the tube and pipe subassemblies are). I believe you'll need to assign the top-level assembly - which will bring in the components of the phantom subassemblies .
Paul
Yes, you are absolutely right.. I was at the wrong level. Each hose need to be a separate run for this to work.
