Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Variable in the Path of the "Client Working Folder:"
2 REPLIES 2
klbosch
609 Views, 2 Replies
Is there anyway to place a Variable in the Path of the "Client Working Folder:" so I can still use "Enforce Consistant Working Folder for All Clients" yet be able to place it on different disk partitions or spindles as hardware allows.
2 REPLIES 2
gradcliffe
in reply to: klbosch
The syntax for variables in the working folder path would be like any Windows environment variables (%USERPROFILE%, %SYSTEMDRIVE%, etc.).  I've never tried that; It might work, and you could set a custom environment variable on each machine to point wherever you like.
I have actually been solving the same problem with SUBST in a custom command script for as long as we've used Vault Workgroup (since the beginning of the product); haven't had a single problem yet, and I think it's a bit more refined.
Here is an example of my script (saved as VaultSubst.cmd):
@echo off
set _VW=C:\VaultWorkspace
if not exist %_VW% (md %_VW%)
subst V: %_VW%
 Usage:
  • Edit "C:\VaultWorkspace" to be your "standard" enforced workspace location
  • Deploy the script to each Vault client machine, to be run at startup (The script could be copied to the user's Start Menu > Startup folder, for example)
  • If necessary, Edit "C:\VaultWorkspace" to be wherever you want the workspace to exist on that particular machine
  • In Vault Administration, enforce the working folder for all clients at "V:\" (or any subfolder of it)
By using SUBST, you get a convenient "drive" at V: that will take you directly to the Vault workspace on any machine.  If you prefer not to see the additional drive letter in Explorer, I think you could make and deploy a similar script that would use symbolic links (MKLINK) instead.
-George
klbosch
in reply to: gradcliffe
Thank You that is excacly what we were looking for
