Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
using autoloaser have massage wse032 error when log in
12 REPLIES 12
Message 1 of 13
425 Views, 12 Replies
hi,
using autoloaser have massage wse032 error when log in,
can you tell me possibility this happen,
and how to solve this,
thank you very much before,
12 REPLIES 12
Message 2 of 13
Senthil_Kumar
Are you seeing the issue only with Autoloader? How about Vault Explorer and other applications like AutoCAD OR Inventor?
If it is only Autoloader I need to know the following information.
1. You system information (OS, Language, x86 or x64...etc)
2. Please send this file C:\Program Files\Autodesk\Vault Professional 2013\Autoloader\Explorer\Autoloader.exe.config
3. Event log from Event Viewer
Also is it happening in only one machine?
Any other information which can be useful for us to investigate please send them also.
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
Message 3 of 13
in reply to: Senthil_Kumar
Yes, it is only happen in autoloader and only one machine,
please see attached file,
thank you before,
Message 4 of 13
Senthil_Kumar
Thanks for the reply. We will look into the files. In the meantime can you please let us know if you have changed anything in the config or not?
Is Autoloader working in another machine? Is there anything different in this machine?
Senthil Kumar
Message 5 of 13
Dear Kumar-san,
i never change any config,
Autoloader is work in other machine but have different problem,
there are only can to map in "design" folder and some machine any message that different version with production,
Message 6 of 13
Senthil_Kumar
Thanks again for your reply.
If you haven't changed anything then I would say, do a repair install for the Vault Client and see if you that works for you.
Regarding your issue on Mapping project to a folder other than the default folder when using Autoloader, please refer the following solution.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
Hope that helps.
Senthil Kumar
Message 7 of 13
before thank you for the link,
regarding error wse032, i already reinstall but still happen,
Message 8 of 13
Senthil_Kumar
If that is the case please log a support case and someone from Product Support will help you with this issue.
Senthil Kumar
Message 9 of 13
Hi, Mr. Kumar,
Regarding for link on Mapping project to a folder other than the default folder when using Autoloader,
<?xml version="1.0"?>
<BUData>
  <ProjectName>Designs.ipj</ProjectName>
  <LibraryName>Libraries</LibraryName>
</BUData>
how to do mapping to "Library Part" folder in "Libraries" folder at project explorer?
because i have sublibrary in library,
how if to do mapping to subfolder in folder at project explorer?
Thank you very much,
Message 10 of 13
Senthil_Kumar
If you have Subfolder under LIbrary then you do not need to place it in XML. You can map to the Subfolder during the Map Folder stage like below. Is that you want?
Senthil Kumar
Message 11 of 13
Hi, Mr. Kumar,
By default all Inventor files be uploaded into the same folder in the vault. this folder is named Designs, but may change the name by using the Rename button (this folder in project explorer, how if i want to mapping to sublibrary in library on project explorer?) .
I can't do like your ficture for inventor file,
How set up BUU.xml file for this,
Message 12 of 13
Dear Mr. Kumar,
By default all Inventor files be uploaded into the same folder in the vault. this folder is named Designs, but may change the name by using the Rename button (this folder created in project explorer, how if i will mapp to sublibrary folder in library on project explorer?.
can you tell me set up BUU.xml file?
For autocad file i  can do like you, but can't for inventor file,
Thank you before,
Message 13 of 13
Senthil_Kumar
This solution has the answer to your question on How to create the BUU.XML.
Senthil Kumar
