Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Use large status icons
8 REPLIES 8
Message 1 of 9
scottmoyse
627 Views, 8 Replies
Does anyone know what this does?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
8 REPLIES 8
Message 2 of 9
mdavis22569
in reply to: scottmoyse
I don't notice a difference when it's on or off ....however this is what they say http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-7EC936C7-12F5-43C9-A038-83DDD8F74C8A Options Dialog Details Use large status icons By default, small icons are used to indicate status. Turn on the Use large status icons check box to display large icons.
Mike Davis
Message 3 of 9
scottmoyse
in reply to: mdavis22569
Cheers for the reply. I should have been clearer, i posted this here because the help file is no help. It would be good if Autodesk included some example imagery in that article. But also if they stated the property name which represents status. There are a few, and then there are the status icons I've highlighted in the image above.
Scott Moyse
Message 4 of 9
mdavis22569
gotcha ...sorry ....
Mike Davis
Message 5 of 9
scottmoyse
Ok this works in Inventor, so it looks like it's broke in the Vault Client. I'll Escalate this to Product Support.
Scott Moyse
Message 6 of 9
Senthil_Kumar
Scott,
It should work. After changing the setting, close the Vault Client and Restart to see the effect. By default Large status icon is enabled.
You can see the difference in the attached images.
With Large status icon Disabled
With Large status icon Enabled
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Message 7 of 9
scottmoyse
in reply to: Senthil_Kumar
Ah ok. I don't believe it says to restart the client in the help file. Inventor doesn't require a restart for it to get applied.
I'll take another look soon
Scott Moyse
Message 8 of 9
Senthil_Kumar
Scott,
I will ask the help team to get that updated. Thanks for pointing that out.
Senthil Kumar
Autodesk, Inc.
Message 9 of 9
scottmoyse
Senthil,
If I'm honest, I'm not convinced restarting is 'As Designed' for two reasons:
  1. When you select Apply, it refreshes the Main Pane of the Vault Client. Why is it refreshing it? Is it because the Options dialog contains other UI toggles and it just does it as a matter of course?
  2. This behaviour is inconsistent with the Inventor Vault Add-in. I'll bite my lip about UI consistency.
Anyway, updating the Help file will certainly clarify the intent. Thanks for passing that on.
Scott Moyse
