Hi Joyce,
I have tried with carb.iam and a new Vault and it runs well. Thanks.
With a new vault, all runs well, but I have a migrated Vault from PS2009 in which I have files with BOM normal structure and it does not run.
If I check-in this iam's (migrated from PS2009) in a new vault, runs well, the migrated vault has a mistake.
I have a lot of properties configured and is a hard work to reconfigure a new vault.
Any idea??
The first time I write for help I was testing Vault because I have the above problem. I was testing with a bad sample.
So, with migrated vault, I obtain an error that say "Cannot assign item" and ipt's are not assigned. If I take ipt's alone, ir runs.
In the Item Master are not Items.
Thanks Royce
Edited by: postventa-msd@adp.es on Oct 15, 2009 6:03 AM
