Vault General Discussion
Distinguished Contributor
warrenandy
Message 1 of 3 (106 Views)
Uploading 200,000+ Drawings any advise?
106 Views, 2 Replies
09-08-2012 03:41 PM
This is probably the second biggest load their will be an even large one later this year. Any advise?
This 200,000+ is AutoCAD with a sprinkle of ACADE. Another 20-30k of Inventor files are already in. Then the larger will be a mix of AutoCAD and PDF files some of them probably date back to the 80's...
Andrew Warren
CAD & Data Management Specialist
Bridgestone Americas Tire Operations
andrew.warren@bellsouth.net
New Member
rantisong
Message 2 of 3 (79 Views)
Re: Uploading 200,000+ Drawings any advise?
09-10-2012 01:59 AM in reply to: warrenandy
You may try with Autoloader which will be installed by Vault client.
-Frank
jclaidler
Message 3 of 3 (72 Views)
09-10-2012 04:53 AM in reply to: warrenandy
Load Inventor files first with 'Task Scheduler' in the following order:
  • parts
  • assemblies
  • presentation
  • drawing
Then using AutoCAD, use the 'check in folder' option.
This is the easiest process.  Not a big fan of Autoloader, except for the reporting part.
John Laidler
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
