Vault Forum
Welcome to Autodeskā€™s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Showing results forĀ
Did you mean:Ā
Upgrade Vault 2012 to Vault 2014
11 REPLIES 11
Message 1 of 12
2593 Views, 11 Replies
Hello all
I'm upgrading old Vault pro 2012 installation to Vaul pro 2014. The new version will be installed
to new server. Is there a guide how this is done? I could find only guides where current server upgraded
to new version.
Do I have to install Vault 2012 Pro to new server -> take backup from current production environment -> restore current environment from backup to new server-> upgrade & migrate to Vault 2014
Or
Can I install the new 2014 directly to new server and restore the current production environment there from
the backup taken with Vault 2012?
Old server
OS: Windows Server 2003 x64
Vault: Autodesk Vault Pro 2012
SQL: SQL Server Express 2008 R2 Service Pack 1
New server
OS: Windows Server 2012
Vault: Autodesk Vault Pro2014
SQL: Don't know yet, SQL server express 2012 if possible
11 REPLIES 11
Message 2 of 12
Kevin.Jaufmann-Ludwig
your second way (install Vault Server 2014 on the New Server and restore the backup from 2012) will work and is the best option in my eyes
Kevin Jaufmann-Ludwig
Technical Support Specialist
Link Name | Link Name | Link Name | Link Name
Message 3 of 12
ihayesjr
Please see the upgrade guide located here: http://wikihelp.autodesk.com/Vault/enu/Help/Help/0305-Vault_In305/0364-Upgrade_364
Irvin Hayes Jr
Sr. Product Manager
Vault - Under the Hood Blog
Message 4 of 12
Can the Vault Basic 2014 upgrade be applied on a Windows 2003 Server rinning SQL 2008 SP2? Requirements say no, however I'd like to know if it will truly not install or if it's just not supported on that OS.
Thanks.
Message 5 of 12
ihayesjr
It will not install.
Irvin Hayes Jr
Sr. Product Manager
Message 6 of 12
RobRidings1
in reply to: ihayesjr
Is this link to the upgrade guide still valid?
Also, if I restore a backup from Vault 2012 into Vault 2014 will it also bring across the conifguration from the previous version?
Inventor Pro 2021 Pro
Vault Pro 2021 Pro
Revit 2021
Navisworks Manage 2021
Windows 10 v1909, 64-bit
Intel i7-6700K @ 4.0GHz
64GB
Nvidia Quadro M4000
Message 7 of 12
yes the configuration settings will be migrated as well.
And yes the link is still valid.
Message 8 of 12
I was reading this thread because I am about to go from Vault basic 2012 to Vault Pro 2014 also.
You stated that the upgrade help link was still valid but when I use it you just go to the online Vault help page.
Message 9 of 12
ihayesjr
Sorry the link isn't working.  Follow this path: Vault Installation -> Upgrade Autodesk Vault -> Introduction to Upgrading Vault.
Irvin Hayes Jr
Sr. Product Manager
Message 10 of 12
tahdesign1
OK I think I already know this opinion here from what i heard at AU this year but I am going to ask about it anyway.
In the help about the upgrade path it talks about having a test environment that is very close to the production server.
I am going from Basic Vault 2012 to Vault Pro 2014. The Vault Pro is on a new server running Windows Server 2012 R2 and SQL Std. 2012.
However, BOTH, of these servers, Old Vault Basic that has been running for years and the new one are Virtual!!!
As a matter of fact ALL of our servers here are Virtual. I know that there was some concern indicated about that when I asked at AU this year but that is not something that I can change. So that being said, what are the actual concerns with using a virtual server environment?
Message 11 of 12
ihayesjr
in reply to: tahdesign1
One of the main concerns with virtual envirnoments is the amount of allocated resources to the Vault image.  If too little resources are dedicated to the Vault image, you could experience performance problems.
Irvin Hayes Jr
Sr. Product Manager
Message 12 of 12
tahdesign1
Agreed but then it is simple to allocate more resources as needed.
Like I have said this is the IT world to which I have to exist so there is no real choice here.
