Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Updating revit sheets in vault
0 REPLIES 0
Message 1 of 1
273 Views, 0 Replies
At the moment I'm experimenting with revit - vault integration. My question is: How do I update the dwf files (of my sheets) in the vault when I've changed the content. I have added the sheets, and the dwf files where created. Now after some actions the vault says that one of my sheets is no longer up to date (sheetname). I get that, because the Revit file has a different sheet than the dwf. So far so good. But now I want to publish an update on the sheet. Here it goes wrong. I've tried: Save to vault, add sheets, publish to dwf (to working folder). None of them worked. The first two options gave no result at all, with the publish to DWF the result was that Vault sees that there is a newer version, but i cannot check in. Also the Add-file for this does not work, because the file name already exists. The update view is not available.
Please someone, enlighten me on how this should work.
Greetz Mark
0 REPLIES 0
