Why do I have, sometimes, "raster"-previews in Vault, when there is no raster-view in these particular idw ?
Only clue is that when I open these particular idw (in inventor), I can see the view being "raster" for a brief instant, than it's OK, without any human intervention.
So it like if the preview (.dwf) was "created" before the end-processing of the view, done after the complete opening, or something like-that.
I have some occurrences, where it about like describe, but when I do a local-preview-update, it fixes the thing (the previews are generated at night by a job-processor on one of the 4 workstations here).
I have other occurrences where re-publishing the preview don't do nothing better.
In all of those cases, I can confirm that there is NO view set to "raster" !
To "fix" that, I have to do a supplementary version of the file, in fact identical, and having the switch "on" (dwf publishing), then publish that newer preview locally, and then it's OK.
Oh, last thing...
i'nt sure if it's the "raster" that does that, but I sometimes have no-text at the end of a leader-text, or offset-text, or similar "bizarrities"... Those are fix all the time by a local refresh of the preview, it does-not "stick" to the version of the idw, like the previous probl.
I'm having a very difficult time figuring out what you're seeing. Would it be possible to post some screen captured of the problems you are experiencing? Also, can you specify the release and flavor of Vault you use? (basic, professional etc).
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
OK, so...
Took a few screen-shot, 3 shown here.
The IDW is "OK" opened in inventor, for sure, nothing done on it, just getted from Vault's V14 (last one).
But that very drawing gives a "faulty" preview, even if we update locally that preview.
I included a previous version's preview (V11), where it was OK...
I'm trying to figure-out what is the "common-point", because like said before, I do have many occurrences. I think of a common thing in the drawings, or from the WStation which did the version of the idw or the WS which was running the Job-Processor, or ???
Since that kinda "cut-and-try" is time-consuming, I taught I could find somebody who had preview-problems and have some solution "easy".
Den
Again...
This time, it's a "disappeared text" condition, and offset-text also, in the title-block...
Here are 3 screen-snap.
1- was to print the preview, saw missing text..
2-went updating, locally
3-result is 100%, except for the file-location, but can't do on that, because the background-inventor-session is .. Like running on a "copy" of the current-project, wish is temporally mounted in the C/Temp/... Too-bad for the info on file-location, but that is no big concern here.
I'm having the exact same troubles. Sometimes I can get the view to update correctly by sending it through the job processor. The moving text problem will only be corrected if I update the view locally.
Same problem here.
Andrew…..I’m not sure if disabling the background updates in inventor is going to solve all the different issues we are experiencing (inaccurate drawing views, missing or misplaced text, very light line weight, etc.). We’ll also install Excel and Word on the Vault server to see if that eliminates the text issues.
I was able to get complete and good quality views with the background updates disabled, but only if the view is updated locally. If I run the view update on the server the result is poor quality views.
Inventor and Vault Pro 2014
