I have been cleaning out my archives, and putting all of our old CAD files into the Vault, to satisfy both IT and Tech Services. There are thousands of CAD files, mainly Autocad, dating back to the late 80's. To save time I added these files using the "Add Files" rather than opening them up individually and checking them in. As a result, and not unexpectedly, they have no visualizations. Any attempt to create a dwf for these old files gives me the following error:
The only workaround seems to be to open the file in Autocad, plot it out on paper to lock in the settings, and then check it back in. Any suggestions? My approach thus far has been... ignore the problem... maybe it will go away. 😄
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This is one of the less helpful errors in this system. If they are older files, they could be in a file format that is causing issues with the dwf generator... or they could have an issue of some kind in the file. I think opening them up and saving them does some cleaning that allows them to go through. Either that or the dwf generation engine in the authoring tools is more robust than what vault uses.
Sounds like a job for a summer intern! Very easy, very repetitive.
Chris Benner
