Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Uninstall ADMS server 2008 on SBS2003 server
4 REPLIES 4
advise
192 Views, 4 Replies
I want to totally remove de ADMS server from my server, including the SQL data. I uninstalled the ADMS with the normal procedure, but the SQL server is still active.
How do i remove the AUTODESKVAULT SQL instance, without affecting the SQL databases of SBS 2003 ?
4 REPLIES 4
in reply to: advise
The sql instances are individually uninstalled in
add/remove programs, so removing one should not affect the other.
The exact naming of the program to uninstall
differs depending on whether you are using SQL 2000 or 2005.
Paul Gunn
still active. How do i remove the AUTODESKVAULT SQL instance, without
affecting the SQL databases of SBS 2003 ? Thanks
advise
in reply to: advise
We are using SQL 2005.
Attached a screenshot of the SQL instances. In the Microsoft SQL server Management Studio express, i can still connect to AUTODESKVAULT.
Edited by: advise on Oct 9, 2008 1:16 PM
Edited by: advise on Oct 9, 2008 1:22 PM Edited by: advise on Oct 9, 2008 1:25 PM
in reply to: advise
In SQL2005, you select 'microsoft sql server 2005'
in add/remove programs and click the 'remove' button.
You will be prompted which instance(s) you want to
remove.
Paul Gunn
We
are using SQL 2005. Attached a screenshot of the SQL instances. In the
AUTODESKVAULT. Edited by: advise on Oct 9, 2008 1:16 PM Edited by: advise on
PM
advise
in reply to: advise
Thanks! That worked perfectly.
