Vault General Discussion
Valued Mentor
Ktelang
Message 1 of 4 (110 Views)
Unassign Item
110 Views, 3 Replies
11-03-2012 12:37 PM
Hello Everybody,
Is there a way to unassign an item.
I mean as we assign item there should be a way to unassign it
I am new to Vault Professional
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
cbenner
Message 2 of 4 (91 Views)
Re: Unassign Item
11-05-2012 05:01 AM in reply to: Ktelang
You can delete an item without deleting the file it was assigned from.  You have to set the item to Obsolete first.
Not sure if this is the best or only way to do this, or what else it may affect downstream.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Mentor
Ktelang
Message 3 of 4 (89 Views)
Re: Unassign Item
11-05-2012 05:45 AM in reply to: cbenner
Thanks will try that
Valued Contributor
sathersc23
Message 4 of 4 (81 Views)
Re: Unassign Item
11-05-2012 09:33 AM in reply to: cbenner
Turning an Item Obsolete can be difficult, I've never figured out a tried and true method to do it.
You can also delete items as a full rights administrator. Usually it's better to re-assign the item number, though we've yet to run into problems deleteing items for non-items (vendor sub-components primarily).
Sam Sather
CAD Admin/Designer
Inventor 2012
Vault Pro 2012 16.1.58.0
Intel Xeon X5690 @ 3.47 GHz
12.0 GB Ram
Windows 7 x64
AMD FirePro V7900 - 8.830.5.6000
"We have not succeeded in answering all our problems. The answers we have found only serve to raise a whole set of new questions. In some ways we feel we are as confused as ever, but we believe we are confused on a higher level and about more important things." - Earl C. Kelley
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
