Vault General Discussion
Employee
paul.gunn
Message 11 of 18 (217 Views)
Re: Unable to restore from Incremental Backup
10-25-2012 07:57 AM in reply to: Neil_Cross
I don't see any reason you couldn't use the same local account information as on your live server. As mentioned, as long as the username and password match up then WIndows is good to go with it.
Paul
Neil_Cross
Message 12 of 18 (215 Views)
10-25-2012 07:58 AM in reply to: Neil_Cross
Apparently I can't use a local account from another machine as the impersonation account, I was hoping it could magically authenticate these credentials but it can't.  I repeat, FML.
Anyway, why does the impersonation account even need rights to that backup?? As long as it can see it, copy from it, it's on an open share...! It's simply just copying from that area... not writing to it?
Neil Cross
CAD & Data Management Consultant
Inventor Certified Professional
Employee
paul.gunn
Message 13 of 18 (211 Views)
10-25-2012 08:05 AM in reply to: Neil_Cross
It sounds like you just need to create a local account with the same username and password as the remote server. Windows will authenticate the user automatically (workgroup authentication).
In ADMS all file access (filestore and backup/restore) is done with the impersonation user - the exception is database backup and restore which requires the SQL service user. The reasoning is that using a common account avoids the need to have various administrators individually requiring access to the backup location.
Paul
Neil_Cross
Message 14 of 18 (208 Views)
10-25-2012 08:11 AM in reply to: paul.gunn
But how can I create a local account on the local machine with the same username as the remote machine?
Local server name is UNIT1664
Remote server name is TW4
I create a user on local machine called AutodeskVault, and the same on the remote machine, it tries to authenticate against the remote machine as UNIT1664\AutodeskVault whereas the account with the same name on the remote machine is TW4\AutodeskVault...? Both accounts have the same name and password, but it won't authenticate as it isn't really the same account.  Or am I missing your point there?
Neil Cross
Employee
paul.gunn
Message 15 of 18 (205 Views)
10-25-2012 08:26 AM in reply to: Neil_Cross
I'm really puzzled why authentication is working from your live server but not your test machine. If you look at the security settings on the backup server, permissions should be just to the 'autodeskvault' account (i.e. windows doesn't really have a notion of security for a user on a specific different machine). So it isn't clear why one machine would work with these credentials and not the other.
It may be that setting up a domain account is the best bet here - even though (as you mention) it could take some time for propagation of permission.
Paul
Neil_Cross
Message 16 of 18 (203 Views)
10-25-2012 08:28 AM in reply to: paul.gunn
How far down the backup structure do the permissions need to propagate? Do they need to just be at top level? Could I propagate down the entire structure but just do folders only, or do the permissions need to be against absolutely every object in the backup set?
Neil Cross
Employee
paul.gunn
Message 17 of 18 (200 Views)
10-25-2012 08:29 AM in reply to: Neil_Cross
Permissions for all files are needed in order to do the restore (as each file must be copied).
Paul
Neil_Cross
Message 18 of 18 (198 Views)
10-25-2012 08:31 AM in reply to: paul.gunn
I had a feeling you'd say that! Rather than chomp at the live backup, I'll just wait a day for it to copy the whole set locally, then apply the permissions locally.
Thanks for your help anyway :smileyhappy:
Neil Cross
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
