Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Unable to open documents in Vault 2014 - Vault crashes
4 REPLIES 4
KevinPfeifer3228
788 Views, 4 Replies
We have a user that is using a Surface Pro and is having issues opening documents of any kind in Vault 2014 professional.  He was able to open files before applying SP 2, now every time he trys to open any kind of file Vault crashes.  "A problem caused the program to stop working correctly. Please close the program."
I have tried going back to SP 1 but still get the same results... any thoughts?
His Surface Pro is running Intel Core 15-4300U CPU @ 1.9GHz, 8GB of RAM and 200+GB available hard drive.
Anyone have any ideas?
4 REPLIES 4
jdkriek
in reply to: KevinPfeifer3228
Is your user able to GET (download) the file to his local and open it with the appropriate application?
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
KevinPfeifer3228
in reply to: jdkriek
Unfortunately no, Vault crashes before it even asks if he wants to check it out.
jdkriek
So if he right-clicks a file and chooses Get / Checkout, it crashes?
Jonathan D. Kriek
KevinPfeifer3228
Correct, it doesn't matter if he right clicks and selects Get/Checkout, Open, View in Window or double clicks the file a Window opens stating that Vault experienced an error and closes the application. There is no error code or anything indicating what the error was.  It is looking like the root cause is that he is using Windows 8.1 which is not a supported system for Vault 2014.  He is the only one in the group piloting Windows 8.1 and the only one having the problem.  We have a work around in place to keep him going until we upgrade Vault.
