I got the same message, however, I remember getting that message as a
warning during the install of Vault. I had installed Vault on a server
that had other web services installed. The problem is that the hotfix
will not install even though the Vault Server will. The workaround I
finally got was to have someone send me a copy of the updated dll and I
just copied it in. Not an official hotfix but I think it worked.
Bob Henry (Autodesk) wrote:
>Marcel,
>Can you connect to the Vault server from other client machines? Or are you
>only using Vault on one machine (server and client)? The reason I ask is
>that you may be using Autodesk Web Server (AWS) and just not realize it.
>However, if AWS is installed that would mean you are only able to use Vault
>on that machine only and other clients wouldn't be able to connect - even if
>IIS were installed AFTER the Vault server is installed. However, if you
>installed IIS first (rebooted) and then installed ADMS, or Vault server,
>then AWS would not get installed and you would indeed be utilizing IIS.
>If you type in this URL into Internet Explorer, is the page visible or does
>it return errors (like 401, etc)?
>http://SERVERNAME/AutodeskDM/Services/KnowledgeVaultService.asmx
>SERVERNAME is the name of YOUR server. Just replace that part.
>Did you have to do anything special when you installed the ADMS like move it
>to a different web site in IIS, or otherwise?
>Let us know and we'll try to help your troubleshoot this..
>Thanks,
>Bob
> wrote in message news:5100938@discussion.autodesk.com...
>When installing the hotfix TS1054281 the error below is displayed.
>-IIS is not running as the default web server-
>However ISS is running as the default web server.
>What else can be wrong.
