Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
troubles with custom properties in Vault
8 REPLIES 8
Message 1 of 9
710 Views, 8 Replies
I am new to working with custom properties in Vault. We are using Vault Basic with Inventor, all 2014.
My trouble is I set up a custom property and used it and am now unable to delete it. When I get usage counts under EDIT PROPERTIES it shows (1). I thought I would be able to find where it was used by searching Vault where this property : is not empty but it returns no results. This same query works correctly on other custom properties. Any ideas where it could be used and how to find it?Vault property usage.PNG
8 REPLIES 8
Message 2 of 9
cbenner
Message 3 of 9
in reply to: cbenner
Message 4 of 9
cbenner
Message 5 of 9
It just tries to tell me I must have at least one mapping...
Message 6 of 9
thomas.rossmeisl
Hi wkoehn,
if you want to find out where the property is used, then you can use the Find feature of vault.
Press CTRL+F to open the Find dialogue and in there you can define a search like:
Look For: Any
Property: SEAL KIT
Condition: contains
Value: *
The reason why your "is not empty" search failed is probably because the property is empty. But this doesn't mean it isn't used.
This should return a list of objects on which the property is used.
Thomas Rossmeisl
Message 7 of 9
in reply to: thomas.rossmeisl
OK that works better. Now my search returns 13555 results which means that my custom property got applied differently than I intended I guess...
Thanks!
Message 8 of 9
thomas.rossmeisl
Ah sorry my fault. I haven't really thought this through. This statement returns every File.
But you can try one more thing. In the options tab of the find dialogue remove the tick for "Find latest versions only". And then look for "is not empty".
Maybe your property is used in an older version of a file.
Thomas Rossmeisl
Message 9 of 9
^^ Perfect! Found an earlier version of the file that was using this property. Once I purged that version the property was able to be deleted. Thanks!
