Hi All,
We recently upgraded to Vault Pro 2015. The when logging into the thin client some machines will not remember the server name the next time they log on. Is there a setting or an add-on or something that these people need to have?
Thanks.
Have you tried to use the URL as follows:
http://vault.webserver.local/AutodeskTC/VAULTserver/VAULTname
If you use this, the Vaultserver and the Vault could not be changed on Website
/VAULTname is an Option, if not needed use the url only with /AutodeskTC/VAULTserver/
Mike,
You can edit the 2015 Thin Client web.config file (located at c:\Program Files\Autodesk\Vault Thin Client 2015\) to make the Vault server static for all page visitors. This value is on line 55 - you'll find some other configurable items in that section as well. Take a look at the attached image.
