Just as the title says. Vault Professional 2015, just loaded SP1 but I had this problem prior to that as well. Logging in to thin client as administrator, the "username or password are invalid". Even though it is the same user name and password with which I log in to the ADMS, and manage all of the Vault.
Also noticed (so far) that after SP1, thin client still not showing watermark on Items.... but that may be a setting?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by ihayesjr. Go to Solution.
I can only assume you've tried and thought about this, but your admin password doesn't have character symbols in it such as " or * or @ ?
Just wondering if the keyboard has maybe changed to a different region so the symbols are being typed differently? It's likely not that, but was the first thing to come to mind.
@Neil_Cross wrote:
@I can only assume you've tried and thought about this, but your admin password doesn't have character symbols in it such as " or * or @ ?
Actually there is one character in the password.... I'll try changing it at the server level and making the attempt again... if it's that simple I'm going to feel pretty dumb.
Chris Benner
I'm in the UK and often Windows Server installs default to using the US keyboard, all the common characters swap around which can cause a slip with the likes of the sa password and such.
Another thing to do is type the password into Notepad first, visibly verify it's correct, then copy paste that into the password field. Worth a go.
OK,... I logged into ADMS as Admin, and changed the password to one with no characters. Tested the password logging into Vault Client and had no problems. Same username and password on Thin Client will not work (I also tried the copy/paste from notepad trick... good idea).
Just to make certain I am not being brain dead... can someone verify the thin client address as http://server/AutodeskTC/Landing
Vault Pro 2015 SP1
Chris Benner
Yea I just manually punched in:
That's the root web page address in IIS and will redirect you to the landing page.
OK,
I am brain dead. Apparently you can only log on in Read Only? Even as Admin?
Chris Benner
Chris,
Do you have Vault Office? If not, then you can only log in as Read-only.
