When we try to open files from Vault Pro 2011 we are seeing the error message: The process cannot access the file C:\Vault\(our company name)vault.ipj because it is being used by another process. If we say to skip it still opens the file but also opens another session of Inventor. This is the message myself and a coworker see. Another coworker has a different error message appear: "SecurityUtilities.SaveFileToDisk() - Read Only File." I think this started happening when someone accidently checked out the project file from Vault...?
We're using Inventor 2011 and Vault Pro 2011. Thanks.
Hello fellow "slaves to the machine", we are getting the same error in a few of our machines. Likewise we are also using Inventor series 2011, but with basic vault.
Any answers AutoDesk?
I am getting this error as well, but am not using vault. Just started using 2011 on this machine, and get the error several times per session (up to 12 to 16 hours).
The process cannot access the file because it is being used by another process.
I am also running Inventor Suite 2011 and am having the same issue. Don't know if it is a bug or what it is but real annoying to have to keep closing and opening Inventor 20 times a day. This happens when I am saving a file, mostly on idw's. We use Vault but I frequently do not sign into it while working on a current project that I have not checked in yet. We wait until the project is complete to check in files. Also having trouble during save where it appears to save but then locks up Inventor and the task manager has to be used to end task just to get out of Inventor. Not liking 2011 at all, 2010 was much better and never had these lockup issues or any other issues for that matter. Sometimes what a company, such as Autodesk, that thinks improvements are necessary and for everybody isn't always the case. Inventor is know a total resource hog that crashes or locks up constantly and the amount of work that can be done has decreased by half or more due to all of the problems.
Has anyone found a resolution for this error message:
I got it today after updating our project file. I tried to perform a "get" operation on the file using Vault Explorer 2011, & that's when the message popped up.
One of the users here is getting the message when trying to Get Latest Version on a part in the Library.
What's causing this and how do we solve it.
Mike
One of my clients had the same problem.
This error occurs when the client does not have write permissions to the Vault working directory.
This often is a local directory.
When write permissions are added for the loggedin (domain)user the error is gone.
