Hi, Dear All,
Who knows the default password for the Windows user "AutodeskVault", it's same with sa with "Autodesk@26200"?
Thanks!
Gengyun
Solved by minkd. Go to Solution.
The impersonation user (AutodeskVault) password is not necessarily the same as the default sa password. I believe the AutodeskVault user's password is generated by the installer - you can find it in the web.config:
<identity impersonate="true" userName="AutodeskVault" password="your AutodeskVault password" />
-Dave
