Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Task Scheduler and Vault Pro 2012
7 REPLIES 7
Message 1 of 8
pdauphin
559 Views, 7 Replies
I have a problem with the Task Scheduler 2012. All the Vault tasks are not showing. The buttons are missing. It is also missing the login option in the file drop down menu.
Basically, it is like the task scheduler is not Vault enable anymore.
Any ideas?
I'm using Inventor Pro 2012 and Vault Pro 2012.
Thanks.
7 REPLIES 7
Message 2 of 8
Senthil_Kumar
in reply to: pdauphin
Looks like there is some issue with Installation and the Vault add-in registration. Can you please do a repair install on Inventor and Vault Client?
Let us know if you still see an issue after the repair installation.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Message 3 of 8
pdauphin
in reply to: Senthil_Kumar
I ran a repair on both Inventor and Vault. In that order. It did not solve my issue.
I checked on other computers and not all of them have the problem. They are all Win 7 Ultimate 64bits, all same version of Inventor and Vault with same updates of these two software.
Any other suggestions?
Thanks.
Message 4 of 8
Senthil_Kumar
Thanks for your reply and I am sorry to hear that it didn't work.
Now we have 2 options.
1. If you are under subscription please contact our Product Support team and log a support case. Someone from Support will look into the machine.
2. The other option left out to us to do a Clean Re-installation of Inventor and Vault Client.
Sorry that I couldn't help you much on this.
Senthil Kumar
Autodesk, Inc.
Message 5 of 8
pdauphin
Thanks for your input.
I'll try a few things and contact support.
Thanks again.
Message 6 of 8
pdauphin
Ok. My problem is solved. I still do not know what caused it but it is now fixed.
I uninstalled Inventor and Vault from my system and then, reinstalled everything. I then applied the service packs and upgrades. The Task Scheduler is now working normaly.
Again, thanks for your help.
Message 7 of 8
Senthil_Kumar
Glad to hear that it works now.
Senthil Kumar
Autodesk, Inc.
Message 8 of 8
thedelee
Good to know, having same issue.
