style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<Hi,
href="mailto:mingying.zhou@autodesk.com">mingying.zhou@autodesk.com>
wrote in message
href="news:6040031@discussion.autodesk.com">news:6040031@discussion.autodesk.com...
Please check the following items: 1. Do you map the Library vault folder?
Launch Inventor and active your project, Files-> Vault-> Map Folder,
please check if the Library vault folder is mapped. 2. If you have mapped the
Library folder, please check if the Library files are used by files in your
workspace. If the Library files is not used by workspace files, then it cannot
be checked into vault. Wish this can help you. Thanks, Shadow Edited by:
mingying.zhou@autodesk.com on Sep 27, 2008 1:31 PM
<Hi,
wrote in message
href="news:6046947@discussion.autodesk.com">news:6046947@discussion.autodesk.com...
I cannot reproduce your issue. The migration and check in works well. Could
you provide more information such as the detail steps or
screenshot?
Thanks very much.
<Jing.Li@autodesk.com>Hi
wrote in message
href="news:6048896@discussion.autodesk.com">news:6048896@discussion.autodesk.com...
smjanows,
I have a question. Dose your workspace and library defind in a
same location? Are they both under a folder which your vault project on? I
noticed your workspace location is C:\Vaultfiles\SRC Engr\, and your library
location is \\2008SERVER02D\Vaultlibrary\Library, I guess they are not same
location. So when you perform check in to vault task, you first set the
project to C:\Vaultfiles\SRC Engr\SRC_Engr_2009.ipj, in this location, just
only have your workspace (SRC Engr), no library folder, so when you browser a
folder in this location, just workspace and its subfolders available. If you
make your workspace and library in a same location and together with your
vault project, that would be ok.
For example:
Vault project:
C:\Program Files\Autodesk\Vault 2009\Samples\Inventor 2009\Padlock.
Workspace: C:\Program Files\Autodesk\Vault 2009\Samples\Inventor
2009\Padlock\Designs.
Library: C:\Program Files\Autodesk\Vault
2009\Samples\Inventor 2009\Padlock\Library.
Note: I met your situation
only the workspace and library definded in a different location.
Hope this
helpful for you!
Scott
Hi smjanows,
I totally agree with you, certainly this is a limitation for current TS, and it is a known issue in R2009, I will push our DEV to fix it, hope it can be addressed ASAP.
Scott
