To get DocumentServiceWse to show up, you need to do the following steps:
1. Install the Web Service Extensions 3.0 from the Microsoft site. Make
sure to select the Integrate with Visual Studio option.
2. In your project, add a reference to Microsoft.Web.Services3.
3. Update your Document Service web reference.
If those steps don't work, it might because that version of Visual Studio
doesn't work with WSE 3.0. The samples are set to work with VS 2005. VS
2003 will not work, and VS 2008 has not been tested. If you are using VS
2008, let me know.
If Visual Studio will not work with WSE 3.0, you can copy over the
references from the one of the SDK samples. Just to go VaultFileBrowser\Web
References\DocumentSvc, copy over the four files, and update Reference.cs to
match your namespace.
Doug Redmond
Software Engineer, Autodesk Inc.
