Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
subscription release 1 service pack 1 - Windows 8.1
17 REPLIES 17
Message 1 of 18
scottmoyse
801 Views, 17 Replies
I've just installed a fresh new copy of Vault 2014 and updated it to SP1 > Sub Rel 1 & went to install Sub Rel 1 SP 1  (not confusing at all incidentally).
But I get the following error:
There are no pre-requisites of build numbers in the Readme file, so I'm not entirely clear on the update path. (Why are there still no build/version numbers in the Readme's? It's crazy.)
Anyway this is the current built & stage I have my ADMS at:
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
17 REPLIES 17
Message 2 of 18
Senthil_Kumar
in reply to: scottmoyse
Scott,
I am little confused. From the ADMS - About info I see that you already have SP1 installed for Sub Rel 1.
18.101.3.0 - is the build number for Sub Rel 1 SP1. You can also see that Subscription Release 1 Update 1 is shown.
Anyway, regarding the error you get, this error comes up when you are not running the SP as Administrator. So RMB on the SP1 MSP and Run it as Administrator. That should solve the issue.
Let me know if you need any further help/info.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Message 3 of 18
scottmoyse
You're confused? I certainly am. So I've installed Vault Service Pack 1, then the Sub Rel 1.... now I've tried to install Sub Rel 1 SP1, but it tells me it's failed.
The Product info calls Sub Rel 1 SP1, Update 1 instead of Service Pack? This Cracking The Vault post calls it Sub Rel 1 SP2 in the Hyperlink name, but it's actually SP1... but does this Sub Rel 1 SP1 actually contain the same fixes as Vault Service Pack 2? So what is it really? A SP? or an Update? oooh gawwwd. Not very good Data Management from the Data Management team....
right back to the task at hand. Oddly, Run As Administrator isn't in the context menu, with or without holding down the Shift key:
Scott Moyse
Message 4 of 18
scottmoyse
Oh & I have full Admin rights & UAC turned off. Only Microsoft Security Essentials is running.
Scott Moyse
Message 5 of 18
scottmoyse
Ok I used Shift+RMB to 'Copy As Path'. Then I ran the Command Prompt as Administrator, pasted in that path and ran it from there. It installed without error.
It ran for about 3 times the amount of time as it did previously. So it's a little worrying that the ADMS console is reporting that it's up to Update 1 for Sub Release 1, when it mustn't have had all of it's components installed.
Thanks for the Administrator tip.... why is it needed even if you have full admin rights?
Scott Moyse
Message 6 of 18
Senthil_Kumar
Scott,
Thanks for your reply and glad to know that it did work. With Windows 8/8.1 or Windows 2012 we have to use this option to run any patches even though we have full admin rights.
Regarding the info in the Blog I have asked the PS team to change that. It should be Subscription Release 1 Service Pack 1.
And regarding the info in the about box I agree that it is not ideal and I will forward your comments to the team.
Subscription Release 1 Service Pack 1 will be shown as Subscription Release 1 Update 1 in the about box.
You can refer this page Vault Build Numbers for the build numbers.
Hope this helps.
Senthil Kumar
Autodesk, Inc.
Message 7 of 18
scottmoyse
in reply to: Senthil_Kumar
Awesome thanks for that link. Please can you confirm that Sub Rel 1 SP1 includes all the fixes in SP2?
Regards
Scott Moyse
MFG Technical Specialist
CADPRO Systems Ltd
>From my Windows Phone
Scott Moyse
Message 8 of 18
Senthil_Kumar
YES. All the fixes that are gone in Vault 2014 SP2 are in Vault 2014 Sub Rel 1 SP1.
Senthil Kumar
Autodesk, Inc.
Message 9 of 18
clastrilla
Hi Scott,
Where did you get the link to download? I've used the link from Cracking the Vault site, and it was broken:
"http://knowledge.autodesk.com/support/vault-products/downloads/caas/downloads/content/autodesk-vault...
It would lead me to this:
Tried searching the Autodesk download page as well, but couldnt find it.
Message 10 of 18
Senthil_Kumar
in reply to: clastrilla
We will be posting this Service Pack ( Vault 2014 Subscription Release SP1) in the subscription center soon. It is already in the process of posting.
Senthil Kumar
Autodesk, Inc.
Message 11 of 18
scottmoyse
well there you have it. It looks like the original location was a faux pas originally.
Scott Moyse
Message 12 of 18
Vault 2014 Subscription Release 1 SP1 is available in the Subscription Center now at
http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=22982844
Senthil Kumar
Autodesk, Inc.
Message 13 of 18
scottmoyse
Is this the same version /build as the original download?
Scott Moyse
Message 14 of 18
Senthil_Kumar
Scott,
Yes it is. Just the posting location is changed since this one is for only Subscription Release.
Senthil Kumar
Autodesk, Inc.
Message 15 of 18
clastrilla
Hi Senthil,
It seems the Service Pack 1 for Subs Release 1 has gone AWOL from the subscription center. I can still see the actual Subs Release 1 download, so I dont think its an issue with my entitlements.
Can you confirm if this has been withdrawn, or misplaced?
Thanks!
Message 16 of 18
Senthil_Kumar
I still see the Sub Release 1 SP1 at http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=22982844
Senthil Kumar
Autodesk, Inc.
Message 17 of 18
clastrilla
Hi Senthil,
Thanks for the quick reply. Thats really strange - when I click on the link you provided, it gives me:
Message 18 of 18
Senthil_Kumar
That's really strange indeed. Let me know if you want me to download and send it via FTP. I need your email ID for that. Please send me an email at senthilDOTkumarATautodeskDOTcom
Thanks.
Senthil Kumar
Autodesk, Inc.
