Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
SQL R2 Express Limit.
1 REPLY 1
BL4849
471 Views, 1 Reply
Can someone confirm that the "10GB Limit" in SQL R2 Express is the size of the SQL Databases and NOT the Total, including the Filestore.
In either case what happens when this limit is reached?
Thanks in advance
1 REPLY 1
paul.gunn
in reply to: BL4849
You are correct - this is a database limit, filestore size is not relevant here.
When the limit is reached, you will start seeing SQL errors usually reported as 109 errors in the applications. The details in the log indicate that the database can no longer be grown.
Hope this helps,
Paul
