Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
SQL express more then 10GB - is possible? Vault very slow!
3 REPLIES 3
2004 Views, 3 Replies
Hallo everybody,
We have problem with performance on our vault server 2011 - sql 2008 express on win server 2008 R2. I know that R2 isn't supported but after migration 2010-10 we haven't so big problem with performance.
We are 8 users working on the INV2011 connected to vault. We migrated  always data base from older version to new version. I know that sql express is limited to 10GB data base. About 3 months ago it's begin working very slow  - INV + vault + content center - I have check ADMS console and vaults SQL databases was 4GB and  libraries database was 14,5GB. Is it possible that after migration sql databases was less then 10GB and later grow and grow and now we have problem? How works sql express then databases  exceeds 10GB?
3 REPLIES 3
Richard.Rankin
It is very possible that the SQL DB will increase in size following a migration.
You could try running the SQL Maintenance plan defined in the Advance Config guide. Part of it involves setting the Recovery Model to Simple, where applicable.
You could also try looking at this blog post
http://crackingthevault.typepad.com/crackingthevault/2010/06/how-toreduce-vault-size-and-generally-i...
Give those a try but failing that, you may be faced with having to upgrade your SQL. I hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Sorry I forgot to give you a link to the Advanced Config Guide
http://images.autodesk.com/adsk/files/advanced_config_guide_-_2012.pdf
See page 25
Richard Rankin
in reply to: Richard.Rankin
thanks Richard for yours advices, they are very usefully information
In my case it will be maintenance script for Vault 2011, I have one from ACG-2011.
I have questions:
Is it correct that I
1-start script from cmd VaultMaintenance.bat  %YourVault%>results.txt
-should all users(vault clients) login out or can they be connected
2-reboot vault server
3-can be problems with performance on INV during reindex properties on the vault server?
4- should I remove the IPv6  even I have installed LNM (FLEXnet) for 2012 products family?
