It is a bad idea to do what you did - the vault
runs on a special instance name called "autodeskvault" when you attached
it to your normal instance of SQL it probably got disconnected from the one we
require.
You should create a new SQL server registration and
connect to (computername)\AUTODESKVAULT for the
server.
