Can a large vault (90 Gb) be split into two?
I guess backup the whole vault.& move off m/c
Then delete all the new projects.
Backup to create a vault of old projects
Rename the vault & detach?
Restore the fist backup (whole) then delete the old projects.
But restoring with a vault detached isn't good practice (I think).
Is there a way?
MES
Hi Mark,
I'm afraid this workflow wouldn't really work (renaming and reattaching the vault) . The vault databases have information inside that uniquely identify them . So you would be blocked on the re-attach if there is already a vault attached with that unique identity.
Could you say what are your concerns regarding the database size?
Paul
Halve off the database is now legacy & only needs to be kept as a record - very unlikely to be used. Was thinking that reducing the database by 50% may improve the speed.
Cheers
MES
If accessing the files is pretty unlikely, have you thought about just storing a backup for archiving purposes and then deleting the stuff you don't need from the production system? If it turns out you need the files then it would just be a matter of restoring the backup onto a separate machine.
Paul
What kind of speed are you talking? We have a 50+ Gb database (over 1.2 million files) and we normally return a search in less than 10 seconds. We are still on VP2012 and that's still 32 bit. Should get better with VP2014.
The legacy would be nice to have, just in case.
Memory is cheap. Having to repetively bring a Vault back is time not well spent.
Just my 2 cents.
