Where is the download for the Solid Works plugin for Vault 2013?
Can't find it on Subscription Center.
Solved by olearya. Go to Solution.
i think you have to get it from your reseller who get it from autodesk
for some reason autodesk doesn't provide it to the public
DarrenP
I too am looking for the SolidWorks Plug-in ... for Vault Pro v2014
HI Mikka,
This is not yet available, I will update this post once it is released. We are planning to make this available via subscription center, so as long as you have a current Vault Professional subscription you will have access at that time.
Hi All,
Please note that the Vault Professional 2014 SWX Integrations are now accessible to subscription customers only via the Autodesk Vault Appstore and customers subscription entitlements. Please be patient if it does not immediately appear under your entitlements.
Is there a plug-in available for SolidWorks 2014 yet? I found the plug-in for 2013 but havent been able to locate it for 2014.
Hi There,
This will be available shortly, I will update when this happens.
Hi Again,
Quick update - the Vault Professional 2015 add-in for SWX is now available to subscription customers via the Autodesk Appstore and presently in subscription center.
Please see the read me for details of supported OS and SWX versions.
Allan, I'm currently trying to locate the Solidwords plug-in for Vault and the link you provided appears broken. I cannot locate the plugin via the App Store or in my Subscription Account (manage.autodesk.com). Any ideas?
