I wonder what does slash sign ("/") mean in Vault properties such as <File Store Size> and <Number of Files in Store> when using console?
Ex. :
File Store Size - 21,23 Gb / 21, 28 Gb
Number of Files in Store - 53808 / 53896
I guess it is somehow related to replication ... I also see that sometimes there is the only number (without slash) in the same console.
What is the meaning of first and second values?
Solved by paul.gunn. Go to Solution.
This is related to replication. The first number is for files on local server (count and size) - the second number is for all files across the replicated system (count and size). When there is only one number then the server is fully up-to-date with replicated fiels.
Paul
Hello, Could this dual value be due to restoring a Vault?
Yes,
You would also see this happening after a Restore. The server needs to do a checksum validation on each file - which can take some time. The validation runs as a background task - this can be seen in 'server tasks' in ADMS console (https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN... ).
Paul
