Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Slash in <File Store Size> and <Number of files> (Vault properties)
4 REPLIES 4
Maxim-CADman77
1404 Views, 4 Replies
I wonder what does slash sign ("/")  mean in Vault properties such as <File Store Size> and <Number of Files in Store> when using console?
Ex. :
File Store Size  -  21,23 Gb / 21, 28 Gb
Number of Files in Store - 53808 / 53896
I guess it is somehow related to replication ... I also see that sometimes there is the only number (without slash) in the same console.
What is the meaning of first and second values?
4 REPLIES 4
paul.gunn
in reply to: Maxim-CADman77
This is related to replication. The first number is for files on local server (count and size) - the second number is for all files across the replicated system (count and size). When there is only one number then the server is fully up-to-date with replicated fiels.
Paul
julian.chica
in reply to: paul.gunn
Hello, Could this dual value be due to restoring a Vault?
Julian Chica
MFG Applications Engineer
paul.gunn
in reply to: julian.chica
Yes,
You would also see this happening after a Restore. The server needs to do a checksum validation on each file - which can take some time. The validation runs as a background task - this can be seen in 'server tasks' in ADMS console (https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN... ).
Paul
julian.chica
Thanks a lot Paul!
Julian Chica
