We just implemented Vault site replication in August to our facility in Poland. We experienced multiple power failures due to hurrican Sandy this week and replication failed multiple times. The power has been restored, but the site replication in ADMS on the publisher was turned off. I turned the site replication on and set the schedule and now it runs when scheduled, but when I check it the following day, the replication is turned off again by itself. I don't want to have to turn this on myself everyday. Can anyone tell whey ADMS is turning site replication off? Any help would be appreciated.
Thanks!
Vault Professional 2012 SP1 running on Server 2008 x32
Solved by jweiss1313. Go to Solution.
We are having exactly the same problem with a customer here. We configure the replication and it works correctly, and then check it the next day in the ADMS and replication is set to "Off" for all vaults on one site.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
I'm the customer.
Anyone got any ideas?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi Scott,
In our case, even though scheduled file replication appears to have turned off in both our Publisher and subscriber ADMS consoles, file replication is occuring as scheduled. We had this problem in both Vault Pro 2012 and 2013. Autodesk is aware of the issue but they do not have a fix that we are aware of.
After this occurred, I created a support case with Autodesk support. They asked that I monitior the file replication to see if it was actually occurring even though ADMS says it was turned off. After monitoring it for several days, they were correct that file replication was occuring as scheduled.
I would suggest that you create an Autodesk support case and monitor your file replication to see if it's happening or not.
Cheers John I will check it out
Scott Moyse
Yup, It is replicating. The last replication date & time is reporting that it replicated last night, but it said it was Off yesterday and still does today.
So Autodesk just need up the visual feedback part of this.
Scott Moyse
Hi Scott,
I would let Autodesk know that you are having this problem as well. Good luck!
Scott Moyse
I just wanted to update the thread that this problem has not been fixed. We are now running Vault Pro 2014 in a full replication environment and last week I noticed that according to ADMS file replication is turned off at both our sites. I'm been monitoring the situation and replication is occuring as scheduled, ADMS is just listing it at off.
I just wanted everyone to know that this problem still exists and this thread is still relevant!
