Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Show Vault file path
11 REPLIES 11
Message 1 of 12
patricksalvador
2864 Views, 11 Replies
 When we do a search with "search subfolders" checked, is there a way to view the Vault file path for a specific file without going to the folder?  Is there any option for this in custom view or properties?
I really need to know what folder the searched files are in.
11 REPLIES 11
Message 2 of 12
You can customise the view to show the "Path" property
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
Message 3 of 12
I cannot find "Path" under the customize view options.
I'm using Vault Collaboration 2011.
Message 4 of 12
The "Path" field is a new feature in Vault 2012. You would need to upgrade to take advantage of that.
Richard Rankin
Autodesk, Inc.
Message 5 of 12
Can I create a "Path" property?  User Defined Property?
Message 6 of 12
yes but you would have to fill it in on every file manually or via code.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 7 of 12
Russ41
in reply to: Richard.Rankin
You guys should be wearing a mask, this is one of the most basic features I can think of - not putting it in and then telling people to upgrade really has a significant impact on your reputation - disgusted.
Message 8 of 12
minkd
in reply to: Russ41
In earlier versions of vault, a file could have many paths because it could be "shared" to multiple folders. All shares were considered equal so there was no "primary" path. Once we finished phasing out shares (we replaced them with links), we were able to show a property in the grid for the path.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
Message 9 of 12
Hi to all
And how i can use path property ? i would like to use it in category assigment but i don't see it.
Message 10 of 12
scottmoyse
in reply to: marcin_otręba
You cant. But you could use iLogic with Inventor to use the path property to drive the value of a custom iproperty which can categorise based on that.
I would imagine it wouldn't be too hard to do something similar with AutoCAD.
Is that any help? I can share code if you need it.
Regards
Scott Moyse
MFG Technical Specialist
CADPRO Systems Ltd
0210557775
>From my Windows Phone
Scott Moyse
Message 11 of 12
marcin_otręba
in reply to: scottmoyse
Thanks!
i know i can do it that way, and i know how to do it but i thought that it
could be easier..
best regards
marcin
Message 12 of 12
scottmoyse
Nope, apparently there are ongoing technical reasons why they cant offer that up as a native vault System/UDP.
Regards
Scott Moyse
CADPRO Systems Ltd
0210557775
Scott Moyse
