Vault General Discussion
patricksalvador
Message 1 of 12 (540 Views)
Show Vault file path
540 Views, 11 Replies
10-21-2011 06:29 AM
 When we do a search with "search subfolders" checked, is there a way to view the Vault file path for a specific file without going to the folder?  Is there any option for this in custom view or properties?
I really need to know what folder the searched files are in.
Product Support
Richard.Rankin
Message 2 of 12 (536 Views)
Re: Show Vault file path
10-21-2011 07:20 AM in reply to: patricksalvador
You can customise the view to show the "Path" property
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Richard Rankin
Data Management Support Specialist
Autodesk Support
patricksalvador
Message 3 of 12 (532 Views)
10-21-2011 07:34 AM in reply to: Richard.Rankin
I cannot find "Path" under the customize view options.
I'm using Vault Collaboration 2011.
Product Support
Richard.Rankin
Message 4 of 12 (528 Views)
10-21-2011 07:51 AM in reply to: patricksalvador
The "Path" field is a new feature in Vault 2012. You would need to upgrade to take advantage of that.
Richard Rankin
Autodesk Support
patricksalvador
Message 5 of 12 (526 Views)
10-21-2011 07:55 AM in reply to: Richard.Rankin
Can I create a "Path" property?  User Defined Property?
scottmoyse
Message 6 of 12 (506 Views)
10-21-2011 05:49 PM in reply to: patricksalvador
yes but you would have to fill it in on every file manually or via code.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
New Member
Russ41
Message 7 of 12 (369 Views)
03-06-2013 07:23 AM in reply to: Richard.Rankin
You guys should be wearing a mask, this is one of the most basic features I can think of - not putting it in and then telling people to upgrade really has a significant impact on your reputation - disgusted.
Employee
minkd
Message 8 of 12 (364 Views)
03-06-2013 10:13 AM in reply to: Russ41
In earlier versions of vault, a file could have many paths because it could be "shared" to multiple folders. All shares were considered equal so there was no "primary" path. Once we finished phasing out shares (we replaced them with links), we were able to show a property in the grid for the path.
-Dave
Dave Mink
Data Management
Member
bystry16
Message 9 of 12 (212 Views)
12-10-2013 01:15 AM in reply to: patricksalvador
Hi to all
And how i can use path property ? i would like to use it in category assigment but i don't see it.
scottmoyse
Message 10 of 12 (210 Views)
12-10-2013 01:28 AM in reply to: bystry16
You cant. But you could use iLogic with Inventor to use the path property to drive the value of a custom iproperty which can categorise based on that.
I would imagine it wouldn't be too hard to do something similar with AutoCAD.
Is that any help? I can share code if you need it.
Regards
Scott Moyse
MFG Technical Specialist
CADPRO Systems Ltd
0210557775
>From my Windows Phone
Cheers
Scott Moyse
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
