Can somebody explain me the value which stands in the bracket? (see screenshot)
Solved by luttena. Go to Solution.
The values you see in your screen shot are the actual values of your content folders. You may want to take a screen capture of your content in your workspace and post it to the inventor Discussion Group. They should have a good explanation of this folder naming convention.
http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Adam
Are you sure this is the actual value of my content folder?
If so, how could it be that the value in bracket shows me 1, but it contains 2 files?
What I mean to say is this is the value of the folder that was created by the Inventor Content Center. The number seems to have no relationship with the number of files in the folder.
Adam
No problem! I hope you get the answer you're looking for.
Adam
