Hi
I have setup a connection between Sharepoint (2010) and Autodesk Vault Collaborataion AEC (2013). I have gotten to the point of being able to search the vault database in sharepoint and am able to download the source file. But when I try to download the Visualization file I get the following error:
Failed to retrieve data from the External System: 'The shim execution failed unexpectedly - Error running BCS command in Autodesk.Vault.BCSConnect: This visualization file is considered to be legacy data..'
What could this be? what is a legacy data?
with regards
Hallgrimur
Solved by ihayesjr. Go to Solution.
Hallgrimur,
This is most likely due to the fact that "Required Synchronizated Visualization" option is turned on in the Vault settings inside of SharePoint. Take a look at: http://wikihelp.autodesk.com/Vault/enu/Help/Help/0305-Vault_In305/0306-Install_306/0356-Install_356/... in the Configure Vault Login section to turn this off.
Yessssss, yeay
I thought I had tested that but that did the trick!!
Hallgrimur
