Everything working fine now with Vault 2015/SharePoint 2013, but one question: If I UNCHECK the box in Vault Settings page that says Allow Visualization Download... what happens? Are users still able to open and view/print the dwf file? Or does this completely disable that ability. I'd like to set it up so that they can view and print, but not download to their hard drives. TIA
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by Redmond.D. Go to Solution.
If you uncheck the box, you get an error if you try to use the Download Visualization link.
Through Sharepoint, there is no way to view or print a DWF without downloading it. So it's all or nothing.
Ok, Doug. That's kind of what I expected to hear. Thanks for responding.
Chris Benner
