Hello,... me again.
Finally got the Vault 2015 - SharePoint 2013 Integration working (more or less), and trying to figure out how I want to use it. I've started by adding a list to a specific site, and I want to edit the Data Source Filters to filter what is viewd on this list. The list is pointing to the Item Master. In IM, I use the property Title (Item, CO) and populate that with the project number and/or Drawing number. I have set the filter to only show Items where this Property contains a specific value. On the Vault end, I have verified that there are Items which have this value in that property. When I save the list and return to the site, I get a message that there are no items to show in this view. I seem to have an all or nothing option.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by ihayesjr. Go to Solution.
In the list, can you provide a screen shoot of where you are setting up the filter? Also, if you remove the filter, does any of the items that are displayed should show in the filter?
I can't get screen shots off of the test server I am working on, as it is isolated from everything else on the network. But here is a screen shot from the documentation I am following....
In the above, I put "Show the otems when column TITLE (Item, CO), Contains, and then I put my project # as the string. These criteria get me null results. Removing this filter gets me the entire Item Master. I AM able to us the State filter to narrow that to Items that are Released.
I have not tried to scroll through the entire list to see if this job # showed with the filter removed. But I will try that next.
Chris Benner
So this filter is a post Vault search filter. So what I mean is that a search is performed when the list is displayed and it gets 100 results from Vault with no search criteria. Then this filter kicks in and filters the 100 items returned. If none of the 100 match the filter criteria then you will get a blank list. You may need to increase your limit.
Further investigation has had better results. I was able to perform this filter with a different project number. I believe the trouble lies with (again) the setup of my test system.
Chris Benner
Chris Benner
