Hai,
How to get the share point 2010 add in for VAULT COLOBORATION 2012, we have not found in DVD media what Autodesk supplied and it is not available in Subscription center.
Pl suggest me.
Madhav.M
Please contact your Autodesk reseller/partner.
Hai Irvin,
Thanks for the quick respond,
This is for your information we are the authorised resellers, we checked it in partner portal and local Autodesk technical manager, regarding this we raise a case" Case Number 06712333 to Autodesk support , still we are unable to get this add-in.
Let me know if any alternative to get this quickly.
Madhav
Hi Madhav,
Just to close the loop on this thread, Autodesk Support should now have pointed you in the right direction for this.
For anyone else needing information on the Microsoft Sharepoint 2010 Integration for Vault Professional 2012, please contact your Autodesk reseller. If you are an Autodesk reseller and missed the briefing, then please log a support case and we can point you in the right direction.
Cheers
