Hello
Have a anybody idea if it's possible to change colour in tree window in Vault client 2013 or 2014?
I mean this situation: When I have selected some folder in tree view window and then I select some file in window view, than selected folder have a almost non visible gray colour.
Can I change this gray colour for example on RED colour?
I tried to make some changes inside xlm file for Vault client setting.
Solved by cbenner. Go to Solution.
These colors come from your Windows theme settings, depending on what version of Windows you are using. They are not set within the Vault Client.
Right click on your Windows desktop and choose "Personalize".
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi ChrisB,
Thank you for reply. This is good trick or idea 🙂 But doesnt works for tree view. In other views (windows) works fine in Vault client, but not in tree view. 😞
Check that in atachment.
OR can be problem on my site. 🙂
It looks like you have an older Windows version... I can't test with that one I'm afraid. We're on Windows 7, and I played with just a few of the themes... there were some "high contrast" themes that set the inactive menu to a nice dark shade. Perhaps try other options than inactive menu.... to see if anything has any effect?
Chris Benner
Same issue as shown in his .png, Windows 7. I search the Vault frequently and use the results to browse to the folder which contains them. Right click on file, "go to folder" in tree shows a faint grey highlight. Why can't Autodesk allow us to choose the color, or default to a nice yellow highlight? Is there a registry hack?
Andy
