I only have maybe one user currently using the old 2010 Vault while the 2012 one is being built. Everything was working last-week and then they ran the Windows patches on the servers over the weekend. Now my user cannot log into the Vault Server?
I can go to the server and I can see ADMS running and look at everything on it. But when you try to log into it from Vault it says the server does not exist?
Any Ideas?
Here are the logs, looks, like I am throwing some kind of exception in here...
I am unsure what the IIS log is really saying. But, I had a Windows / Company update that knocked my firewall settings taking the machine "offline". Is it possible that the firewall was reset and that is blocking you from the server?
-Jim
I ran Server Dianostics and it says it cannot connect to SQL Server' .\AUTODESKVAULT'
Anything is possable, but this is a big operation and the firewall is not on the machine. I mean the only thing that could be blocking would be the prot correct?
Does this one help?
I am going to have to take a step back here and make sure I understand things.
Are you able to log into the ADMS Console?
a. What do you see? (i.e. your vaults and such)
b. Can you see the users if you go into the Administration area?
If you cannot see the ADMS Console, is SQL running?
-Jim
I can log onto the server and I can see everything in ADMS I even defrag-ed just in case. I can go into SQL and everything looks like it is running fine their as well???? I can not figure out why it is not working.
The only thing that does not work is when the client try to connect to the server, or when you run diagnostics.
I would try resetting IIS and see if that helps. Based on what you are telling me it seems like the server is there and working. So usually with the clients it is either a firewall blocking or IIS.
-Jim
I went to support and they had me try it with the IP address. That worked, then we tried with the full server Domian name (ie <domainname>.com). I think it may be fixed this morning I seemed to be able to log in with the old regular server name. Waiting on my user to get here and test it to see... Not sure what IT did this weekend but one of the updates messed somehting up...
Interesting... I would have not have expected the direct IP to work. But since it did, does a ping from the client to the server return the same IP address? If not, you might want to try a flushdns on the client machine.
-Jim
I am not sure what happened but everything is back today...
Thank you for all the help!
We have the same problem, and it only occurs with some users, me for example. The user can log into the Vault server with the server name for several months, then one day they cannot. Server cannot be found, or with windows auth, the user account cannot be authenticated.
Once you change the server name to the IP address, everything works again. I am guessing the network guys are doing something to the DNS and active directory, without knowing that it is effecting the windows authentication features of vault. We tried ipconfig /flushdns, it does not fix it. But changing from the server name to the ip address almost always fixes it.
Glad to see you were able to get it resolved.
When you ping the server from the client, does it return the proper IP? Unsure if this could be it, but have you recently changed your Domain password? I am just trying to think of any weird network things that could cause this.
-Jim
