Hello Everyone,
This is my situation,
I just upgrade to 2015 version, I have installed Vault Basic 2014. My server is 32 bits, but I can not install the new Server 2015 because it is only for 64 bits. I have been thinking the followoing but I donĀ“t know if could be applied
- Can I install Inventor 2015 with vault client 2014 and server 2014?
- Can I instal inventor 2015 with vault client 2015 and server 2014?
Any advice?
Thanks in advance.
Luis JosƩ Andueza Castro
Ing. MecƔnico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
ĀæTe resultĆ³ Ćŗtil esta publicaciĆ³n? No dudes en darle Me gusta a esta publicaciĆ³n.
ĀæTu pregunta fue respondida exitosamente? Entonces haz clic en el botĆ³n ACEPTAR SOLUCIĆN.
Solved by DarrenP. Go to Solution.
nope
if your going to Inventor 2015 you will need Vault 2015 for server and client
DarrenP
ThatĀ“s what I was afraid of.
Thank you for your answer.
you could install Vault 2015 server and continue to use Inventor 2014 and Vault 2014 client
it works this way
DarrenP
