Hello Everyone,
This is my situation,
I just upgrade to 2015 version, I have installed Vault Basic 2014. My server is 32 bits, but I can not install the new Server 2015 because it is only for 64 bits. I have been thinking the followoing but I don´t know if could be applied
- Can I install Inventor 2015 with vault client 2014 and server 2014?
- Can I instal inventor 2015 with vault client 2015 and server 2014?
Any advice?
Thanks in advance.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
Solved by DarrenP. Go to Solution.
nope
if your going to Inventor 2015 you will need Vault 2015 for server and client
DarrenP
That´s what I was afraid of.
Thank you for your answer.
you could install Vault 2015 server and continue to use Inventor 2014 and Vault 2014 client
it works this way
DarrenP
