I have made some interface changes to my vault dialog in what I see and how things appear when I open Vault client.
We are about to this weekend have our systems reloaded and I am looking for a way to save these settings. Similar to how you save (export) settings within Inventor under "Application Options" and "Customize".
Can this be done in Vault?
Hi Scott,
Here are some locations that contain some of the XML files that set your preferences. In these locations you will find files that will save how your grid view appears, your shortcuts and your search history, jus to name a few.
C:\Users\<USER>\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_11_15_2011\<Server>\Vaults\<Vault Name>
C:\Users\<USER>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<Server>\Vaults\<Vault Name>\History
C:\Users\<USER>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<Server>\Vaults\<Vault Name>\Objects
C:\Users\<USER>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Objects
C:\Users\<USER>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\History
You might find project Thunderdome interesting...
http://justonesandzeros.typepad.com/blog/2011/05/thunderdome-2.html
Thank you. This is very intriguing!!!
I am going to look into this one. A shame this is not already incorporated into the vault client.
I saw this on the "Idea Station" the other day. I gave it a kudo, but since this project is underway, hopefully it will become part of Vault.
I have been copying the folder like Ron listed for quite a some time.
